How to change the home button
is it possible to change the home button without having to remove the screen and if it is can you make a guide to it. i have a iphone and the ribbon broke to the home button so i was wanting to repair it myself to save money, can you help please
좋은 질문 입니까?
댓글 5개
What if the digitizer doesn't come with a home button
John Fisher 의
you can buy the home button or the flex separately at most online shops. before you do that just check the dock connector for dirt and dust where it makes contact with the home button prongs. also check that the prongs haven't been flattened through use...gently lift up a little using something like a flathead screwdriver.
pollytintop 의
Its just the screen everything else works
John Fisher 의
sorry, i'm not sure i understand. are wanting to replace the home button or are you worried that the digitiser has no home button?
pollytintop 의
John Fisher 의
