The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
112 질문 전체 보기
Engine not going over 1000 RPM and falls back down
Engine not going over 1500 RPM and falls back down while my leg is still on the pedal and transmission is in park and the car’s not moving. What it might be? Transmission issue? Engine? Thanks in advance!
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
have you had the codes read?
의 답변
의견 추가하세요
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
1개의 답변
가장 유용한 답변
@tillhimself
does the engine ever go over the 1500RPM even if the transmission is in park or neutral? This does not sound like a transmission issue but either a fuel or sensor issues. I’d check things like bad crank shaft, cam shaft position sensor, MAF as well as a throttle position sensor. It is of course also possible that your car is in limp mode. You need to give us more information as to how long this has been going on and if there was anything that preceeded this. You also should consider having the OBD scanned to see which codes you are getting.
Disconnect the battery and wait for 15-30 min then reconnect. (make sure you have your radio code if your radio requires one)See if that changes anything.
해당 답변은 도움이 되었습니까?
점수 3
의견 추가하세요
귀하의 답변을 추가하십시오
Sergio 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 35
