Has power, has sound, black screen... HELP PLEASE
PLEASE HELP ME!!!
OK I bought a LG 55LB5900UV-BUSWLJR 55” LED TV knowing the screen would flicker on for a second and stay black for 5 seconds then flick the screen on for 1 second and repeats as long as the TV is powered on.
Did my research and narrowed it down to bad LED lights and I would have to replace the strips. So I ordered brand new LED strips (made sure they fit my TV by checking the panel number and strip number) and installed them.
Now, when I plug up the TV and power it on the screen just stays black, but its powered on and has sound.
Two things I'm concerned with when I did the LED strip replacement :
1. When I removed the sheet that lays on top of the LED strips and the bulbs stick out of, the clips that hold it down were hard to remove and brittle so I broke the majority of them and didn't use them when I put the TV back together. Could that cause a problem?
2. After I installed the replacement LED strips, I had to reconnect the LED connections that power the LED lights. But when I removed the connections from the original strips, they were pretty snug and I had to squeeze the sides and pull up to remove them and it took some effort to do so. But when I tried to reconnect the connections, it wasn't locking into place and would easily pop out with any movement of the wires. All of the connectors did this so I taped them down with electrical tape and rebuilt the TV to see the black screen... Could it be that the taped down connections aren't getting a good enough connection to power the new LED lights, causing this black screen ?
LG 55LB5900UV - BUSWLJR... Have power, have sound, black screen.
Thanks in advance for any input towards finding a solution to the problem!!
Update (08/21/2018)
Here are the boards.
Update (08/21/2018)
This is a video of what's going on
0
Update (08/26/2018)
Here is the P801 Connector
Update (08/26/2018)
This is my current state with the tv. I don't have sound because my speakers aren't plugged up. Seems to get dimmer after a few flicks too. I can navigate the inputs, the channels, and the menu with the remote, it all just flicks.
Update (08/27/2018)
Is it possible to get these LED strip connectors mixed up and still have enough power to flicker but not stay lit?
좋은 질문 입니까?
댓글 1개
Hello,
Did you solve it. I have same exact issue with my LG tv
Shijo Thomas 의
