주요 콘텐츠로 건너뛰기
3MB 공유 L3 캐시 1.8GHz 듀얼-코어 Intel Core i5 (Turbo Boost 최대 2.8GHz)
371 질문 전체 보기
Boots up when insert battery, can’t shut off
I am trying to replace a battery in a MacBook Air and as soon as I put the new battery in, the device boots up. If I then turn it off, it boots up again within a few seconds. It seems impossible to turn it off so it stays off. Does this mean there has been a short somewhere? There was no water damage that I know of (not my machine).
Thanks!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Reset SMC by Pressing shift + control + esc and use power button to boot into recovery mode in that there is an option to reset SMC
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Thank you for the reply!
Actually right after this comment I tried putting the new battery in again, and when it booted up I held the power button down to turn it off. Now, instead of starting up again right away by itself like it used to, it won´t turn on at all, even when plugged in with power cable. So not sure what´s going on there. Would this be a logic board issue?
댓글 달기
귀하의 답변을 추가하세요
Vera 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 23
