Because you asked, “Does the screen need to be physically attached to the base in order for the touch to operate correctly?“ I just assume you haven’t tried operating it without it attached to the base. You should try that and see if it operates properly because as oldtutkey03 said it doesn’t have to be attached as long as it’s connected. I have seen generic parts customers bring in they ordered themselves act up because of exposed conductive traces being shorted by the metallic body of the iPad which can usually be fixed by covering those traces with kapton tape. In most cases you can tell the quality of the digitizer by looking at the color of the traces. The higher quality digitizer tends to have smaller gold or copper colored traces and the lower quality digitizers have larger silver colored traces. If it still does not work without being attached to the base than it may not be the traces, possible defective part or could be the ultra-rare software issue, which I only bring up because you said the original works fine, to me that points away from the touch IC. For that I backup if possible and just reformat the device but I definitely wouldn’t rule out a problem with the touch IC.
7 Comments
Michael Simonello 의
Michael Simonello no it does not. It will have to be properly connected to the logicboard but you can try its function even if it is not quite assembled.
You can move your screen in all directions but you can not choose the icon to open?
oldturkey03 의
That is correct. I cannot select any icon. I cannot swipe to power off. I can move the screen left right up down by swiping the screen.
I also noticed that if in camera screen if i touch an area on the screen the camera focuses to that area. So something is noticing where I touch but has no effect on icons.
Michael Simonello 의
That is correct. I can move screen in all directions but cannot select any icon. I cannot also swipe to power off.
Michael Simonello 의
So it’s responding to the slide of your finger but not the tap of your finger, correct? When you turn on the device are you unlocking it with your thumbprint?
Blaked89 의
2에 댓글 더 나타내기
