주요 콘텐츠로 건너뛰기
Released November 2016, the PS4 Pro features upgraded hardware for 4K gaming and improved PSVR performance.
382 질문 전체 보기
Why is my disc drive not taking in the disc?
Hello ppl of the internet I have a problem with my ps4 where when I try to put the disk inside the optical drive it won’t go in unless you force it and jam it in. I also find it weird that when the ps4 isn’t booted up fully the disk goes in when I try to put it in but then it immediately goes out I need help my ps4 pro is from 2017 Christmas btw.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개:
Did this just start randomly happening or did it happen after a drop or something? Have you taken it apart and tried to fix it?
댓글 달기
답변 1개
The answer to this depends upon the reason for the malfunction.  Take a look at the drive.(Note: you will need to remove the drive for this.)  There are 2 arms that are the triggers for the loading of the disc.  If these arms are just loose without any tension, then the spring that provides that tension is either broken or missing. (There are You-tube videos that show this.)  Also, try moving these arms outward from center and watch the other ends of the arms  There should be a small PC board with a tact switch mounted on it that triggers the system to start the load process.  This switch may be malfunctioning as well.
The other possibility is that the loading gears are out of "timing".  This usually happens when someone forces a disc and causes the gears to skip a tooth or two.  This is a little more "fun" to address, but rarely happens so lets hope that this is not the case.
Dan
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I'd love to hear a more in-depth answer to this whole gears out of timing thing! The truth is that there is no such thing as timing on those gears. Please delete that out of your answer as it can be misleading to those who are trying to figure out their problem.
댓글 달기
귀하의 답변을 추가하세요
Luis Alfredo 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 103
