4 wire door lock
My top load 4 wire switch not locking. Light blinks. Fills but then nothing.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
Because the washer will fill with the lid open it will not proceed because the switch is either faulty or the plastic peg is broken that goes down thru a hole and activates the switch. Keep your hands safely away and use a dry stick to poke the switch to see if the machine will start to agitate. If not then order a switch or lift the lid and see if the wiring is loose.
댓글 달기
