주요 콘텐츠로 건너뛰기
Third generation Surface Pro tablet, released June 20, 2014.
123 질문 전체 보기
Screen won't turn on after replacement, computer is running.
I have just plugged a screen replacement for the microsoft surface, and though the fan is running and the computer is definitely on, the screen won’t so much as even light up. My old screen was doing this before removal, but it had been cracked for some time.
Is it possible something is blown on my motherboard? I may have forgotten to remove the battery connector before removing the initial cracked screen.
I’ve also considered that it may just be a fried ribbon cable.
Any help would be most appreciated.
Update (08/20/2018)
The bridging pieces are still there for sure. I had read something about the driver possibly being messed up when the computer gets turned on without the screen attached. I definitely turned my computer on after removing the screen initially to see if it was still operational.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
So that's all anyone has for me? Seriously? Just the one answer that gets regurgitated regardless of the problem?
댓글 달기
답변 2개
선택된 답변
Have you tried using a micro HDMI cable to an external display to test that it is actually running? That should work even without the LCD attached.
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
yup. thing was my minidisplay was also broken, but just today i received a dock and am using the computer in question to type this comment
Then I can only imagine three possible answers. Either you put the connector bridge in the wrong way (it will go in upside down), the cable got damaged, or the LCD you received is defective.
It was the LCD cable! thanks so much
댓글 달기
가장 유용한 답변
The battery and display connector have a bridging piece with pins on it which can be very easy to lose when you remove the screw and cable from the connector on the board.
Those are required for a connection to the ribbon cables.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Not my issue. both bridging connectors are in place. I have already researched this issue enough to have covered such bases.
댓글 달기
귀하의 답변을 추가하세요
Norman Wolfe 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 8
전체 시간: 2,110
