vertical bars on my display
My Macbook Pro shows vertical lines on the right side of the display, sometimes it changes to pitch black, sometimes clear lines while sometimes just clear lines.
Images:
https://res.cloudinary.com/ichtrojan/ima...
좋은 질문 입니까?
댓글 3개
Hey! Did you get it fixed? I am facing the same thing, and I went to Apple Care and they said it might be covered under warranty if there is no breakage or outside damage. Did you get it fixed?
Gajendra Yadav 의
I have the same problem with the exception that my laptop completely went into shutdown mode and will not come back up to function. Apple is doing nothing and accepts no responsibility. My laptop was fresh out of the box and used very little when this issue appeared. Was not bumped, moved or closed with anything in it. So, it's very true that this is a defect with the laptop and/or the workmanship that was involved.
Joy Morris 의
i had the same thing and it cost me $678 to repair the screen. smh
Adhitama Harya Saputra 의
