Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
865 질문 전체 보기
Why cant I hear music? not from headphones and not on docking?
my ipod is completly fine- i can play songs and they are working, but its like the sound doesnt go out, not if i use the docking connection and not if i use headphones, what can i do?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
noam, any news on your ipod?
의 답변
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
1개의 답변
선택된 해법
noam, try to squeeze the iPod just to the bottom right around the 4o'clock position from the clickwheel and see if that makes a difference. The 5th gen logic board has an issue with the audio decoder chip that comes loose on the logic board. When you squeeze it, sometimes hard, you force it to make a connection and the sound will be audible, while you squeeze. If this is the case then the only fix are to either reflow the logic board or to replace it. Logic Board is available here and instructions are here. There is some interesting homebrew fix on here look for a posting from warnergt. It might just work for you. Of course all this only applies if there is nothing else that is disconnected or visibly not working. Good Luck and let us know how it is going.
iPod Video (30 GB) Logic Board 이미지
상품
$20.99
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
귀하의 답변을 추가하십시오
noam 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 1,554
