주요 콘텐츠로 건너뛰기
The Nokia Lumia 920, developed by Nokia and released in November 2012, utilizes Windows Phone 8 operating system.
56 질문 전체 보기
Phone is acting weird like it was back button pressing itself.
Phone is new. It was never used before. It was unboxed from the sealed package. After powering it is acting strangely. It vibrates and it looks like back button is being pressed constantly.
I have opened it up.
When it is opened it is not doing that but I can’t use opened phone :)
Any help will be appreciated. ( I have tried to change touch sensitivity but it wouldn’t help)
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
If the bottom lights are flashing it usually means the battery is flat and needs to charge up to turn on.
Leave it plugged in the charger for about an hour and it should turn off.
If you just opened it up sealed in box don't forget to insert the battery. (I could be wrong but this model may not have user battery)
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
It is not power issue. Phone is charging without problems. Its starts also without problems but after a while it acts like back button was being pressed repeatedly. It vibrates and all apps/setting are closing...
댓글 달기
귀하의 답변을 추가하세요
smallbigsquare 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 104
