주요 콘텐츠로 건너뛰기
Smartphone designed by Xiaomi in the Redmi Note line.
55 질문 전체 보기
redmi 4 not turning on
redmi 4 last night battery drained fully morning connected to charger presses power button mi logo appeared stuck with same mi logo after 20min so again pressed power button continuously to turn it off , since then no beep, no led , no response tried with multiple ways connecting with laptop usb , different charger , different connecting point , even removed & connected battery pin , No luck , pls suggest almost imp data & reports from past 3days am stuck
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Check out this article How to fix mi logo stuck during boot process, bootloop problem solution this will help you even i have solved my issue.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Balraj raj 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 11
전체 시간: 138
