주요 콘텐츠로 건너뛰기
The Xbox 360 is the second game console made by Microsoft, and was released November 22, 2005.
462 질문 전체 보기
right trigger button keeps firing when I let it go
when playing a game ie with guns the right trigger button keeps fireing when i let go of switch after that if i tap it some more it will turn off then when i press it again the same thing can this be fixed thanks jacob
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
의견 추가하세요
답변 3개
선택된 해법
try getting some canned air or a soft brush and see if you can remove any dirt/old sweaty skin cells etc that build up around the button which can cause it to jam.
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
The best you could do would be to take it apart and see if you could clean that area. I would recommend a brush or q-tip with rubbing alcohol. In order to open the controller you need a security tox screwdriver, you can get them off of eBay for a decent price.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
What about replacing the trigger sensor. They sell replacement parts on ebay for that.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
jacob k 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 46
전체 시간: 13,267
