주요 콘텐츠로 건너뛰기
MacBook Air 11"의 2015년 3월 업데이트는 5 세대 Intel Core i5 및 i7 프로세서를 장착하고 배터리 성능이 약간 향상되었습니다.
140 질문 전체 보기
MacBook Air won’t turn on, freezing, crashing, spinning rainbows
MacBook Air purchased early 2015 won’t turn on,
I get a black screen with the Apple logo and a loading strip which doesn’t load. There is no water damage to the device but the hard drive is full.
Currently need the contents for Uni assessments. Have tried power cycling, SMC? Reset, holding shift, control and alt with the power key, holding command, power and the letters R and P, and holding shift and power which gives me a nearly full loading strip but unfortunately freezes right before success - so frustrating.
I have no tools to open things and I’m hoping to get it repaired before Tuesday (today is Saturday), any ideas welcomed.
TIA MShell
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Do you have access to a second Mac which you can interconnect your system to using Target Disk Mode?
How to use target disk mode to move files to another computer
If you can you should be able to gain access to the files, At least save your stuff. Then reformat the drive and re-install the OS. You should be able to recover your drive.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Thank you so much
댓글 달기
The solid state drive has failed. Will need to replace and reinstall Mac OS
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
SD Card 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 118
