The First Generation of line of Ford Trucks known as the Super Duty.
19 질문 전체 보기
My F-250 Super Duty with 5.4 gasoline engine started sputtering and sh
It would not restart. I was told by a friend to replace the fuel filter and did so and it still does not start. What could be the problem?
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
아이폰 배터리 수리 키트
Only $29.99
Buy Now
아이폰 배터리 수리 키트
Only $29.99
Buy Now
1개의 답변
가장 유용한 답변
Are there any codes being cast . Do you hear the fuel pump hum ? To check this turn on the key and listen at the side of the truck for a humming sound it should last about 5 seconds or so after turning the key . if you dont hear it you probably have a fuel pump issue and will need to replace it . You may also have an air issue check the air filter if it is plugged bad enough it can cause the same issues . Your best hope for finding the problem is to get the codes read and go from there . Hope this helps
해당 답변은 도움이 되었습니까?
점수 3
의견 추가하세요
귀하의 답변을 추가하십시오
epbritton 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 1
전체 시간: 23
