모델 A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 또는 3.1 GHz Core i7 프로세서
156 질문 전체 보기
iMac A1418 Black Screen 3 led On but 1 Off
Hello
After changing the disk on the SSD, a gray vertical bar appeared on my screen.After the next opening I had a few colored vertical stripes on the screen.I opened it again and I drank the tape on the power and plugged in. Now the screen is black. Make it start (dong ) there is a fan but no image. On the main board only 3 LEDs are light but the last 4 Led is off. Where do you look for a problem?
Update (09/03/2018)
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
@suprnowa what exactly do you mean by this "I drank the tape on the power "? Did you recheck your data dispaly cable? Check that and the connector for any damage.
의 답변
Yes i unplug my data display cable on power
의 답변
So i connect external video whit thundrbold-hdmi and work fine.
I have a picture on the external display. The only thing I noticed Mac is running very slowly. I have to change LCD Panel?
의 답변
의견 추가하세요
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
2개의 답변
선택된 해법
@suprnowa start with this
LED 1 + LED 2 + LED 3 + LED 4 = Power is available, the system is turned on, the logic board is communicating with the GPU, and the internal LCD was found.
If the fourth LED is not visible after the system is turned on:
Verify the internal DisplayPort cable (eDP) connections between the LCD panel and the logic board.
Inspect the LCD display cables for cable damage.
Verify external video functionality and proceed according to the result:
If an external display works, verify/replace the LCD panel.
If an external display does not work, verify/replace the logic board
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
So i have one question.
If there is an image on the external monitor, the system works very slowly. The LCD Panel could have broken down so that it is black and does not illuminate and display nothing? Did something else on the motherboard get worse from the power / control LCD Panel?
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Piotr 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 42
전체 시간: 355
