주요 콘텐츠로 건너뛰기
A corded phone with companion cordless phone developed by Uniden.
8 질문 전체 보기
Why can't I hear a dial tone on the base phone?
On my base phone, if I use the speaker phone, I can hear the dial tone and talk.
If I try to pick up the receiver and talk, I can’t hear the other person. I also can’t hear a dial tone at the start of a call.
The cordless handset works fine. It’s only the base that I have a problem with.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
Hi @cstofko
You mentioned that the corded phone is having issues,
Had you tried this?
Ask someone to make a call to your telephone number, pick up on the defective set.
you will not be able to hear, but try speaking on it. Does the remote caller hear your voice?
If the remote caller does not hear you, consider getting another cable to change from the base station to handset.
see if it work.
or test with another handset.
else dismantle the handset and check on the internal speaker if it is working.
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
Thanks so much for your response! The person I'm talking to can hear me. How would I dismantle the handset and check on the internal speaker? That sounds complicated.
I got a new cord to connect from the receiver to the base, but that didn't help. I thought it would because I can faintly hear sounds in the base, but the sounds don't come through the receiver.
Hmm, seems the plastic is being glued together, check for any screw holding.
Note: hopefully it is just the bad soldering connection, sometimes when you drop the handset, it came loose.
you might need to find a inconspicuous area to use an exact o knive, etc to perform a small incision and use some stuffs to slowly pop up the plastic.
best if you can standby a multimeter and to check to connectivity of the internal cables, speakers (ohms range) and from the jack to the internal point.
댓글 달기
귀하의 답변을 추가하세요
Connie Oswald Stofko 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 4
전체 시간: 1,687
