Screen doesn’t turn on, phone works
Everything seems to work except that the screen doesn’t turn on. Not even with a replacement screen. Any way to fix this without doing difficult soldering?
좋은 질문 입니까?
좋은 질문 입니까?
Did you forget to unplug the battery before doing the screen replacement?
Try shining a flashlight on the screen and see if you can see dim display which would mean the phone has a backlight issue, that requires board-level / microsoldering to repair.
해당 답변은 도움이 되었습니까?
Screen seems pitch black, even when shining a flashlight on it. It also doesn’t seem to respond to touch since I cant click the ‘allow’ prompt. The water damage stickers are all red, too. But everything works perfectly fine except the screen. I can probably trow the device away at this point right? Or is this fixable?
If the stickers are all red, sounds like the phone has liquid damage.
You can do a quick check by removing that black cover near the screen connectors. There's also one near the battery connector and charger port as well.
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 49
