주요 콘텐츠로 건너뛰기
다양한 카메라 분해 및 수리 안내서.
7868 질문 전체 보기
Black Spot - 1 centimeter black "sun"
I have Samsung ES70- 12.2 megapixels and did not use it long time 1-2 years.I recharged and everything looks OK, screen and menu and all different menu screens working OK, but on ALL screen display I see right in the middle,an one black ball/spot of 1 centimeter.
I did format and reset to factory settings, took out battery and memory card, then always that black “black sun”in the middle. Why, and how to repair??
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Sometimes in 1 or 2 times from 10 times it is OK so no pixel problem….
댓글 달기
답변 2개
선택된 답변
Hi,
It may be an intermittent connection to the display (or in the display itself), so that the pixels are not being turned on
Here’s a link to a video that shows how to replace the LCD screen in the camera.
At 6:34 minutes into the video the LCD display cable connection to the motherboard is clearly visible.
Without a schematic of the cable connections it is hard to tell which connections are the problem ones (if it is at this point).
Unfortunately the only way to determine if the problem is in the display or in the motherboard is to replace the display and check if the problem still occurs.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
It sounds as if it’s dead pixels and you need to replace the screen. You can find replacements on a number of sites (like Amazon, ebay, etc.) and instructions on how to replace it on youtube.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Wim Rippen 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 133
