주요 콘텐츠로 건너뛰기
MacBook Air 11"의 2015년 3월 업데이트는 5 세대 Intel Core i5 및 i7 프로세서를 장착하고 배터리 성능이 약간 향상되었습니다.
140 질문 전체 보기
Won’t turn on
Hello!
My MacBook Air just won’t turn on.
I just plugged it in to charge one day and now it won’t turn back on. The charger lights up orange when it is plugged in. When the chargers plugged in and I hold down the power button at the same time it lights up green.
I had someone look at it and they said it was probably the battery or the connector to the battery and that I should buy the new one of those.
I took it to the Apple store, they said there didn’t appear to be water damage or corrosion but that the typical start up tricks weren’t working and I would have to send it off and it could be up to 700 dollars for repair, which I can’t afford.
Please help!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Lets start off by opening the system and disconnecting the battery following this IFIXIT guide: MacBook Air 11" Early 2015 Battery Replacement Follow the steps to stopping on Step3 with the battery disconnected with your MagSafe adapter plugged into the AC connect it to your system the system should spontaneously boot up, did it?
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Catherine Morkel 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 53
