Media sound not working? SOLVED
Media sounds not working. Notifications & system sounds are fine.
좋은 질문 입니까?
좋은 질문 입니까?
Also another thing to check is to make sure you do not have do not disturb turned on or turned on as scheduled. Depending on how it is setup it may mute all media sounds.
해당 답변은 도움이 되었습니까?
Thanks. It started working after I left it off for an hour.
Thanks... checked and it was my “Do Not Disturb” mode was on. Don’t know how it got enabled but it was in and fixed my problem.
If your tablet is anything like mine when you hit the volume keys there is a dropdown, maybe the media tab is all the way down.
Alternatively you could have somthing wrong in the system. I had a problem like this where i had to go to a boot menu and clear some temporary data on the
해당 답변은 도움이 되었습니까?
Thanks. It started back up after I left it off for an hour.
Make sure it is not connecting to a Bluetooth device
해당 답변은 도움이 되었습니까?
Thank you thank you thank you Malcolm, that was the solution for me. My tablet was connected with my hearing devices, which lay around somewhere in the living room.
24 시간 전: 4
7일 전: 28
30일 전: 109
전체 시간: 22,117
댓글 9개
Thanks for the input guys. It's loud & proud again.
Richard 의
It's working again. Needed some down time I suppose. It's loud and proud once again! Thanks
Richard 의
Sounds goes up and down by itself
drury.stephen 의
I have a problem of my new tablet A. It has no sound, i can’t hear any voice . All is set in settings but still no voice
Monlisa Lim 의
I waited on my comment to be answered..
Monlisa Lim 의
댓글 4개 더보기
