주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display, 모델 A1502의 2015년 3월 업데이트는 5세대 Intel Core i5 및 i7 프로세서를 포함하며 Force Touch 트랙 패드를 소개합니다.
1185 질문 전체 보기
Large number of this model no longer turn on
With semester starting up I have had about ten of this model come into university service center with same issue:  Does not turn on!
Reset SMC, tried power on pads with keyboard as well as with the airport card, SSD module, LCD disconnected - still no help.
When under warranty I ordered replacement logic board and left I/O board which had fixed the unit in the past.
Now many are off warranty. Why are so many of these models failing?  Anyone else seeing a large number of this model with same issue?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Being in a university environment I’m sure these systems batteries are well used and given the age I think your issue is likely battery.
I would order a replacement battery for testing using a good known system disconnect its internal battery and plug in your test battery to charge it up. Then do the reverse with your dead systems using this battery. Are you able to get them to boot up?
You also may find the MacBook Pro 13" Retina (Late 2013-Early 2015) MagSafe 2 DC-In Board may need to be replaced.
I find this Apple T/N is useful in identifying many power type failures Apple Portables: Troubleshooting MagSafe adapters
MacBook Pro 13" Retina (Late 2013-Early 2015) MagSafe 2 DC-In Board 이미지
상품
$14.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Tom Morin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 29
