주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4873 질문 전체 보기
Back light coil L1503 Digikey supply
Has anybody ordered backlight coils off Digikey (fot the iphone 6,6s,7)and if so what is the part number they are using please?
I have read somewhere that the same specs as written in the schematic to match up on Digikey, the size is slightly different so this person setteled on a slightly lower rating to match the size
Thanks
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
1개의 답변
선택된 해법
The problem with some of the components that Apple uses in their designs is that they are either custom designs or only available with huge MOQ. You are correct that the Digikey models will not work as they are 2.8mm square and they simply will not fit. Some coils on the backside of the board are also hard to source because they are only 0.6mm high and everything standard is 1mm. It doesn’t sound like much but when you consider the density and clearance available, it makes a huge difference.
As for L1503, I order them from China. However, be aware that you never really know what you are getting because they are not “officially” labeled. I once ordered a batch from Jestar, a reputable supplier and when I checked them with an LCR meter, I realized that they were 1uH and not 15uH.
If you are going to using a different rating, keep in mind which ratings do what. For a coil, you have the inductance, the current rating and the ESR (equivalent series resistance). Using a slightly different inductance may or may not cause issues. The ESR is important because it causes internal heating and can have an effect on the overall performance (resistors, capacitors and coils interact and cause all kinds of filtering actions). Finally the current rating is what can make a permanent repair into a ticking time-bomb :>).
There are plenty of people selling this coil both stateside and internationally, that’s the preferred option.
해당 답변은 도움이 되었습니까?
점수 2
댓글:
Thanks Minho. I have just ordered a few IC's from that same supplier week ago, but have also recently read that what they are selling is junk. Can only give it a go. Trial and error. Thanks for your time
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Lee 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 6
전체 시간: 73
