Whirlpool Quiet Partner 1 - only "Options" lighting up
Model # du1055xtss2
Dishwashing not running at all. The only buttons on the control panel that are lighting up when pushed are the 3 “Options” (Hi-Temp Wash, Sani Rinse, Heated Dry). The “Cycles” (Pots Pans, Normal, Light, Rinse Only) will not light up when pushed and are not functioning. The “Start/Resume” is not working either.
Wondering if it may be the thermal fuse or possibly the control panel itself. Hoping to avoid a service man repair cost. If help moving forward would be greatly appreciated.
좋은 질문 입니까?
댓글 1개
Thanks. I did read that thread prior to posting but found it to not be relative to my problem. I’m having no issues with my latch.
I did try to reset by shutting off the breaker for 3 minutes. No change. The drain pump did not run after turning the breaker back on (something I was told to listen for). At this time, the only thing that is working are the lights on the control panel for the “Options”.
J. Horvath 의
