John Deere stx 30 wiring between fuel and fire
I have a John Deere stx30 with a Kohler command 9 on it. Its not starting. I have figured out if i pull the wire terminal off the top of the coil it will get spark out of the plug, but still no start. I next sprayed starting fluid down the air filter spot and it did start. After that I pluged the terminal back into the coil and sprayed some starting fluid and it wouldnt start. Im guessing i have a igniton problem , but not sure how the firing of coil, and power wire of the carb are related. There is a little box on the side of the motor that has 3 wires on it , but doesnt seem to be tied into these wires but not sure . Any thoughts on what I should try next?
좋은 질문 입니까?
댓글 1개
send it to a shop
grant 의
