주요 콘텐츠로 건너뛰기
The first generation Neon was introduced in January 1994 and manufactured until August 1999. It was available as a four-door notchback sedan and a two-door notchback coupe.
Why cant I change from vent to defrost
vent floor defrost knob spins back to vent when itry to change  it to defrost
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Hey Chris. Your A/C ducts in your dash are controlled by little doors that direct the air flow. On modern cars the actuators that control the doors are electric motors. Older cars are vacuum controlled, but I believe yours are controlled with cables. You’ll need to take apart your dashboard and inspect the cable and the blend door itself. It sounds like your cable is binding up. If you can get in there and get some pictures, post them here and I can guide you further.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I don’t remember how the AC is controlled, but I used to have a 98 Dodge Neon R/T and removing the AC controls is very easy to do. Replacing it is also just as easy if you can find a replacement set of controls in a junk yard. You need to see how they are operated first to determine if they are controlled by cables or electric.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
chris beeman 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 10
전체 시간: 422
