주요 콘텐츠로 건너뛰기
Sony's PlayStation TV entertainment system released in October 2014, model number VTE-1001.
10 질문 전체 보기
My ps tv won’t connect to any controller I think my usb may be broken
I’ve had my pstv for about 3 years didn’t use it for about 6 months when I pulled it back out I tried connecting my controller to the back and it wouldn’t turn on my controller wasn’t connecting I tried others controllers same thing which leads me to believe its the USB port it may be damaged because nothing seems to connect/power on when I plug my usb in and just trying to see how I can fix it
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Hi, I finally found a solution.
PROBLEM: my modded PSTV USB port was not giving any sign of life anymore. I tried every single method of connecting a PS3 or PS4 controller, nothing. The port was not charging controllers, so it seemed dead. Some threads pointed to insufficient power being the issue. I found my original PSTV power unit, but still that did not solve the problem. My PSTV being hacked, I did not want to got through the pain of resetting everything to factory standards and reinstalling everything.
SOLUTION: I connected a PS3 controller via Y-cable to a USB power unit and to the PSTV. It worked! Then I could also pair my PS4 controller. All set!
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Is there a picture you have of your connection because I have the same problem. I fear the usb port might be damaged and I run my henkaku from a usb stick.
댓글 달기
It might be just that.
but have you tried connecting a usb hub then your controller? if it doesn't work then, then its the usb port on your pstv
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Sunny D 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 15
전체 시간: 1,223
