주요 콘텐츠로 건너뛰기
The 8th generation Honda Accord
33 질문 전체 보기
Why do only two of my door locks work?
Trying to get all door locks to work
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Only the driver side and passenger rear work with the switches and key the other two dont. So do i need that actuator thing for the other two doors?
In that case that is most likely the problem, yes. It could also be damaged wires or a loose connector, however. Take off the door panel on one of the two non-working doors and unplug the wiring harness that plugs into the actuator. Have someone hit the lock/unlock button while you test for voltage present at the wires with a multimeter. If you have voltage on the correct wires at the right times then your actuator is faulty. Here's a detailed video of how to replace them that will also help you dissassemble the door panel to test those wires.
https://www.youtube.com/watch?v=ByAt_vAO...
댓글 달기
답변 1개
선택된 답변
Hey Mark. Which two door locks aren’t functioning? Do the non-working locks still not work when you use your key fob, the lock switch on the driver’s door, AND the doors themselves? If they DO work from any of these 3, then the switches that don’t work are likely the problem. If the locks don’t work with any of the 3 switches, it’s likely the lock actuators themselves.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Mark Hilliard 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 18
전체 시간: 948
