주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2128 질문 전체 보기
Always enters recovery mode, even when updates successfully
I have a 6S that is a bit weird. It goes to the Apple logo then recovery mode. it always enters recovery mode, even when updates successfully, it keeps entering recovery mode. No error code appears because the update is successful. I’ve disassembled this and the board gets warm when updating, not hot like it has a short anywhere but quite warm.
Really weird one this and I’m not 100% sure what testing can be done to figure this out, possibly testing certain voltages first?
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
Both responses above are valid things to try but neither has changed this particular phone yet .
Seeing this now on a 6 Plus that looks pristine. Baseband removed just in case, but same situation, no obvious shorts. Anyone have any information about this type of issue?
의견 추가하세요
답변 3개
가장 유용한 답변
I have had issues with phones saying they completed updates successfully but really don’t.
How are you recovering it?
I have had much better luck connecting it to a computer and using iTunes to push the latest operating system to them.
Let us know if that worked!
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
Try leaving recovery mode by holding the power button and the home button to hard reset it, or plugging it into a computer and using 3u tools to exit recovery mode
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
I have this same issue with an iPhone 6s Plus I’m working on. It is able to receive and install the update and restarts like it should, but immediately goes to recovery mode after that. I’ve seen this a few times in the past but haven’t had the time to sit down and dig deep into why this is happening. Trying to resolve this without data loss, but haven’t found a resolution yet.
해당 답변은 도움이 되었습니까?
점수 1
댓글:
I wasn't able to solve this case, not enough time to spend on it, but a really tricky one, would like to know more about it
의견 추가하세요
귀하의 답변을 추가하십시오
Elliot 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 27
