Why games run slowly?
I have toshiba sattelite, it was runnig fast when open games but now it runs slowly.
좋은 질문 입니까?
좋은 질문 입니까?
1 - What are the games recommended spec?
2 - What are your specs
Or do u already meet them for sure?
해당 답변은 도움이 되었습니까?
* The game is pes 2017, recommended spec is (core i3 + intel hd 4000)
* I have the same spec in my pc.
First check updates for your windows and then for the drivers install them clear cookies and junk files. Open task manager after running the game and check is there any program running on higher processing that may be the last reason for your game to run slow. If still problem occurs you need to check is the copy of game faulty In general if the specifications are up to the mark the games will hang due to temporary, junk and cookies.
해당 답변은 도움이 되었습니까?
You could check with Can You RUN It if your hardware is compatible with the game you are trying to play.
Although, if you say you could run the games before, it’s probably do to another problem. The most commmon reason for bad performance on laptop is overheating (besides bad specs).
You could try to run some tests as described here and find out.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 55
Share your model number and graphic cards and Ram details
Amily Grey 의
Toshiba Satellite C50-A562
Intel hd 4000
Ram 4gb
Tarek Nacer 의
