The optional mobile computing cart with a space-saving design makes it easy to charge, manage, and store up to 36 systems at once. An LED light lets teachers easily see that all devices are actively charging.
4 질문 전체 보기
How do I bypass the enterprise enrolment without prior account info?
Can I bypass the enterprise enrollment google lock if I don't have previous account information and can't obtain it?
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글:
please help sir
의 답변
의견 추가하세요
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
1개의 답변
I did this to my school issued chromebook and it worked
  1. Press "esc" + "refresh" + "power" (note: "refresh" is the 4th key from the left on the chromebook, it should be the swirly arrow)
  2. Press "ctrl" + "d"
  3. Press "Space" (the spacebar) Note: This will put you in developer mode, let your Chromebook load up everything and do NOT turn it off yourself. Your Chromebook will restart and then start initiating dev mode, that will put you off of the domain
If developer mode is blocked on your chromebook, do this:
  1. If you see that dev mode is blocked, do NOT turn off your chromebook, it will take you back to register your chromebook again do NOT go through this process, instead, try pressing "esc" + "refresh" + "power" again
  4. Repeat this process continually until it works
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Lacey Beaudoin 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 14
지난 7일: 51
지난 30일: 225
전체 시간: 419
