SSD upgrade 2018 model
Hello,
Is it possible to upgrade the SSD in the latest MacBook Air (2018) model, or has Apple soldered it making this impossible?
Thanks…
좋은 질문 입니까?
Hello,
Thanks…
좋은 질문 입니까?
The 2017 model uses the exact same design as the 2015 model. The only difference was an upgraded CPU chip as Intel stopped producing the chip Apple was using.
Here’s the IFIXIT guide you’ll need to follow: MacBook Air 13" Early 2015 SSD Replacement and here’s the needed SSD [연계 제품이 누락 또는 비활성화 됨: IF123-123]
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 3,730
댓글 3개
There is no 2018 model as of yet. The most current model is the Early 2017 13"
Dan 의
Thanks Dan!
From what I understand from the demo below, a 2017 13"'s SSD should be replaceable; do you agree?
Thanks...
Dav 의
Yes you can replace it with either the OWC SSD or the custom Apple SSD designed for your system.
Dan 의
