주요 콘텐츠로 건너뛰기
Released December 3, 1994 in Japan and September 9, 1995 in North America. Models SCPH-100x, SCPH-3000, SCPH-3500, SCPH-500x, SCPH-550x, SCPH-700x, SCPH-750x, and SCPH-900x.
73 질문 전체 보기
The pause menu repeatedly keeps coming up
I have an old Playstation1 and when I was playing Gran Turismo on it the pause menu came up even though I didn’t press the start button, and no matter how many times I press continue the same thing happened again and again. I know there is no problem with the disc seeing as I was experiencing the same thing with Hydro Tunder. I’ve already tried resetting and turning it on and off
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
It’s probably a problem with the controller seeing as the Analog isn’t working and I didn’t have the issue with my second controller
댓글 달기
답변 1개
가장 유용한 답변
You might want to try a new controller and see if the issue persists there. Try a different controller and see if this behavior continues.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I agree. The controller might be suffering from a sticky button, and that's usually due to dirt buildup, grime, and possibly food causing the button to stick. A temporary solution is to gently pull the button back out, but the best thing to do is take the controller apart and clean it. Sometimes the membrane pads will lose their strength, causing the 'spring' to cease functioning. If that happens, the membrane pads need to be replaced, or the remote needs to be replaced.
댓글 달기
귀하의 답변을 추가하세요
AdamsMatthew 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 47
