주요 콘텐츠로 건너뛰기
A collection of guides and support to help with washer repair.
3466 질문 전체 보기
Why is my washer leaking?
My top load washing machine is leaking water from the bottom while running. When we originally bought it, they said the washer had a leak. When we got it home, it wasnt leaking. When we got the dryer a few weeks later, we had to move the washer to get the dryer in. Now it is leaking again. What could be causing this issue?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Cause 1
Drain Pump
The drain pump pumps water out the drain hose. If the drain pump is cracked or damaged, or if the bearings are worn out, the drain pump may leak water. The drain pump is not repairable—if the pump is leaking water, replace it.
Cause 2
Tub Seal and Bearing Kit
The tub seal might be torn, causing water to leak from the seal. If the tub seal is leaking water, water may leak through the tub seal and into the tub bearings. This can cause the bearings to fail. For this reason, if the tub seal is leaking water, replace both the tub seal and the tub bearings. Be aware that this is a complicated repair and will require disassembling most of the washer.
Cause 3
Tub Seal
해당 답변은 도움이 되었습니까?
점수 5
댓글 달기
귀하의 답변을 추가하세요
Rachel Neighbors 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 73
