주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
The Nintendo DSi is the third iteration in the Nintendo DS line, and made its debut in Japan in late 2008.
200 질문 전체 보기
White Screen "?MENU" With r4 Card
I’ve been trying to get my r4 card to work for days now, and I’m getting a bit at a whits end. All it shows when I open up the r4 game is a white screen with a red SD card with “menu” written in it.
It’s a completely new r4 SDHC 2018 GOLD PRO. It’s a completely new SD micro card. I’ve tried changing the format, getting _DS_MENU.DAT files, getting patched ROMS and all that, and absolutely nothing has worked.
Is it because it’s a DSi? It was supposed to be supported by the r4, but the more I look around the more I can see many saying solutions will only work with DS lite.
Is there anything I can do???
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
Nintendo Switch 수리 키트
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
답변 4개
It sounds like you may have not set the r4 up correctly, here is a video on how to do it. hope it helps. https://www.youtube.com/watch?v=CWxmNJgl...
해당 답변은 도움이 되었습니까?
점수 0
댓글:
That did get me further this time thank you. However now I'm just stuck on a loadingscreen where it says with red text that the card is fake and I should return to retailer? But I bought it fom a site recommended by others. Do I really need to get a new card?
I had this problem too, you just need to make sure you have the right Kernel for your R4
의견 추가하세요
The R4s are a bit touch and go with DSi units, I had one work for two systems, but not work for three others, all causing the same issue. You can try another card, or if it’s easier, another device. I believe it’s got to do with the last few system updates that were pushed out for them before they were left for the 3DS.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
But I have a 482 in one ds cartridge witch isn't a r4 card but how do I get the ds menu day back on that too
의견 추가하세요
Thats an error that shows when you have not installed the correct kernel, for the r4 gold pro, the root of your micro sd card, should look like below,
moonmemo
moonshl2
R4iMenu
R4i.dat
We currently have r4i Gold on sale for $27 & Free shipping.
http://www.r4cardstore.com/R4-Gold-Pro
해당 답변은 도움이 되었습니까?
점수 0
댓글:
I have those exact files and folders in my SD card but It still doesnt work. I keep getting the ?MENU error picture...
의견 추가하세요
Welp do u have a r4.dat file in the sd?
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Signe Engberg 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 21
7일 전: 308
30일 전: 1,020
전체 시간: 11,077
