주요 콘텐츠로 건너뛰기
A1708/EMC 3164 — 2017년 6월 출시, 이 기본 레벨 MacBook Pro는 (OLED Touch Bar가 아닌) 기존의 function keys를 유지합니다.
563 질문 전체 보기
Stipe on my screen MacBook Pro 2017
Hi guys
I’ve an issue with my screen
I hope I won’t have to change it.
Apple charge 700euros
I still can do it myself for half price.
But I’m wondering if it’s a cable issue or a screen because sometimes at a certain angle there are no stipe
If anyone could help me
thanks by advance everyone
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 5개
선택된 답변
So I replaced the cable display unfortunately it did not change anything, this is so weird because sometime the screen is absolutely perfect, so I still don’t want to change the screen
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
So what did you do to fix the problem?
댓글 달기
가장 유용한 답변
Hook it up to an external monitor and see if the problem persists.
Also Apple offers a “Flat Rate Repair” on machines without impact or liquid damage. It costs $357 in Texas with shipping and tax included. They will fix any and all problems for that price but you have to contact corporate Apple directly.
What is your purchase date?
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
With an external screen there is absolutely no problem
I live in France, I went to an apple store yesterday and they told me that it would cost 700euros to replace the screen
My warranty (1year) went off in august :(
댓글 달기
If you say it is fine at certain angles then it might as well be the display cable. I would try changing that out first. If that doesn’t work, make sure the cables are secured and plugged in tightly. Lastly, if those two things do not work for you then a new display might be necessary.
@mayer Ideas?
해당 답변은 도움이 되었습니까?
점수 1
댓글 4개:
I didn’t expect an answer so fast ;)
I forgot to add that, but there is no stipe when the screen is black or very dark colour, like when you open Netflix
@archi51 That is certainly a display cable issue. try replacing the display cable and report back the results!
I'm gonna change it, I'll let you know the result. Thanks guys !
@archi51 Sounds like a plan. Keep us posted!
댓글 달기
Man I am having the same exact problem as you, maybe this machines are defective look: MacBook Pro 2017 Display Glitching Very Badly please let me know if you fixed the issue, it would help me a lot, Thanks in advance.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hello Thibaut,
Have you been able to change the cable?
I have the same problem and my warranty was over 3-4 months ago.
Keep us posted!
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Hi
I changed it but nothing changed
So I changed the screen
But check on internet because apparently this problem could be taken in charge by Apple as it happens to many people, for me as I had already open the computer It couldn’t have worked
Hello,
I gave my macbook to service on last Thursday and they called me today and told me that the problem was in the display screen itself. They checked the wires, connections etc but could not find a problem. Then decided the problem was the screen. It is approx. 450€ here in Turkey but the guy did not recommend me to replace the screen at this point. He told me that I should wait until the screen goes completely black, then I should give it to service for the backlight replacement issue.
The funny part is, even they could not define the root cause for this problem!
Anyway, I do not know how long I can continue using my device because it effecting all the video playing/color displaying processes.
댓글 달기
귀하의 답변을 추가하세요
thibaut 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 849
