주요 콘텐츠로 건너뛰기
The Dyson AM07 is a bladeless tower fan released in 2014. The AM07 uses "Air Multiplier" technology to create a smooth stream of air without using visible blades.
19 질문 전체 보기
Air intake on base totally clogged how to clean
On the base of the fan the intake totally clogged with dirt how do I take it apart to clean
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 7
댓글 1개
It's got loads of dust coming out the holes I have COPD and wheelchair bound so I haven't got a clue I'm on my own?
댓글 달기
답변 4개
가장 유용한 답변
https://www.instructables.com/id/Dyson-A...
Please see the above article I posted on how to take apart and clean the internals of a Dyson tower fan.
해당 답변은 도움이 되었습니까?
점수 3
댓글 4개:
Perfect cleaning manual!
Thanks!
If only I had remembered to take a picture before cleaning.. It was so full of dirt. as though Dyson had stuck one of their vacuum cleaners to a ring to come up with a fan.
Very good! I just wish that I’d looked online first it would have saved me so much time! I’m glad you put in that bit about the ring not being made to dissemble…….I thought it was me….I had spent ages trying to find release points but to no avail. Thank you rakone that was spot on.
Thanks! Glad my answer helped.
Do upvote it as i'm new here :)
I'll try to transfer over that instructables to ifixit soon.
댓글 달기
Vaccum with a brush attachment..obviously use a powerful vacuum..this upkeep should be done biweekly
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
You can remove the cover and the filter of the tower fan with the help of this video here. You can then clean the cover and/or change the filter.
https://www.youtube.com/watch?v=UXwqFhfG...
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
No Aaron, read: AM07, NOT the Pure Cool!
댓글 달기
One way is to spray water on the inlet holes and clean the accumulated solid dust with a toothbrush.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Whojuno 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 18
7일 전: 62
30일 전: 315
전체 시간: 61,357
