주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
2015년 9월 25일 출시. Model A1687/A1634. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
921 질문 전체 보기
Touch ID inoperable after a screen repair
I changed the screen on a 6s+ screen, moving over all the small parts. Everything went smoothly until the phone powered back on with the new screen & the Touch ID fails to setup. It doesn’t even attempt to.
I made sure to transfer the original home button, & left the battery disconnected the entire repair.
Somewhere said to change the whole touch id cable from the screen assembly but the cable runs inside the screen which seems to be impossible to change without tearing. Do i just have a faulty screen? The home button click still works
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
SKIP THE UPGRADE
Save by fixing with an all-in-one kit.
Shop iPhone Fix Kits
SKIP THE UPGRADE
답변 2개
선택된 해법
When you transfer over everything, it’s always possible that you damaged the small flex on the Home Button or the connector. The Link Flex is embedded in the backlight on the 6S so you can’t really replace it. If the Home Button Flex looks good (inspect it for tears), then try it on your old screen again to see if it works with that. If it does, then you probably have a defective replacement part.
해당 답변은 도움이 되었습니까?
점수 3
댓글:
Yes your totally correct although it’s not really embedded it’s just behind the shield and easy to replace. I usually replace everything as standard so forgot The old home button should work on a new link flex with Touch ID working fine. Sounds like it’s not connected fully, damaged or a duff new link flex. As you said.
The Link Flex is embedded in the backlight on the 6S series (and not really designed to be user replaceable) while it's only in the heat shield for the 6 series. The OP notes that he/she has a 6S Plus.
의견 추가하세요
You do need to use the old Touch ID flex too. Prize it up really carefully without folding or piercing it. You need to remove the metal backplate to get to all of it.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
there is no flex cable, it goes into the fused display layers
의견 추가하세요
귀하의 답변을 추가하십시오
Trans1000 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 110
