LCD Flex Cable Reseating
If you are reseating the lcd flex cable after repair and you fiddle with it to get it back in can that cause any issue
좋은 질문 입니까?
좋은 질문 입니까?
Fiddling with it shouldn’t cause any issues but in extreme cases, it can damage the connector, either on the screen end or the logic board. If you suspect you damaged it, then look at it under magnification to see. If the pins are physically damaged, then the connector has to be replaced (logic board) or the screen replaced depending on which connector end is damaged.
해당 답변은 도움이 되었습니까?
I think I might’ve damaged the flex cable. I kept connecting and disconnecting due to getting a faulty housing. And my screen has alot of lines but when i put it in an odd position the screen works perfectly fine
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 196
