주요 콘텐츠로 건너뛰기
Repair guides and support for your Samsung TV.
2166 질문 전체 보기
Vertical lines on the side of my tv! Please Help!
I have vertical lines on my TV
(samsung s60fh-yb03), i’ve tried nudging parts on the T board
and removing the flexes
, however when I remove each flex I noticed that it removes a portion of the screen horizontally whilst the lines are still visible vertically on the rest of the screen, so I don’t think i’ve been messing with the correct flexes. I’ll attach pictures of the screen, the flexes i’ve been messing with and the T Board. Thanks for your help!
Added more pictures as requested
Update (10/11/2018)
@oldturkey03 added more pictures as requested
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
Was the display hit or dropped? This is very common for a broken LCD panel.
의견 추가하세요
답변 2개
가장 유용한 답변
@calskius
double check your model number. It appears as if you gave us a screen model not a TV model. This is a plasma TV and thus does not have a T-con board. You a pulling the wires of your YSUS boards and therefore you are seeing the results. It could be a sustain board error (Z or X sustain board) but we need to see more of your boards and a proper model number. Post some good pictures of all of your boards and the wiring layout with your question so we can see what you see. Use this guide Adding images to an existing question for that
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
Slap the back where the lines are until the screen comes back This worked for mine . “if this works its not a permanent fix.”
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
callen dale 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 211
