주요 콘텐츠로 건너뛰기
The HP Pavilion dv6500 is an affordable multimedia notebook with a 15.4" screen , a stylish case, and a security fingerprint scanner.
10 질문 전체 보기
Working charger won't power or charge laptop.
Have a DV6500 HP laptop with good battery and charger. Suddenly it will not charge or power up when charger is plugged in. When I charge the battery on another laptop and put in the defective one, the laptop will run fine. I have replaced the charger board but no success.
Any Ideas?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Thanks for the answer, but unfortunately that did not solve the issue. I’m thinking it may be a hardware issue in that it was charging the battery and then suddenly stopped. The charger has tested good, the battery is good and I have changed the charger board out. The computer works fine with a battery, unfortunately I cannot charge the battery or power the laptop with the charger.
댓글 달기
답변 1개
가장 유용한 답변
HI:
I would say you have a corrupted battery driver, did you know the battery needs a driver to charge.
Got to control panel and find device manager, Battery, uninstall the drivers and re boot with charger plugged in . Windows will be looking for a driver API, you may have to go to the internet to get the driver, install it and reset again.
I hope I understand your explanation and this works.
Good luck.
Alton
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
csand 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 415
