메인 콘텐츠로 스킵하기
The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
249 질문 전체 보기
Why isn't my iPad air getting charged?
Hi. my iPad responds or recognizes the charger being plugged in but dose not charges (i eve used different chargers to check if it was my chargers fault but NO) and after like 3 hours of charging it shows only the apple symbol and if remove its the same thing dose not have charge at all asks for charging again so….should just replace the battery or is there some other problem …? (and apple store is charging 2000 INR just for check up and its like day light robbery so asking for help over here )
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
1개의 답변
선택된 해법
Make sure you’re using the appropriate charger as if you’re using a smartphone charger it might give insufficient power and cause constant reboots. Next would be to try cleaning the lightning port, it might have accumulated small dirt parts with time. If those steps don’t solve your issue a replacement battery might be a good idea. In case a new battery won’t work either, charging port replacement or logic board troubleshooting might be needed.
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
귀하의 답변을 추가하십시오
vikasvarma s 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 29
