How to solve 2n2907 Transistor Troubles or 2n2907 Replacement
Good day!
I am having issues obtaining my board to drive a 2n2907 semiconductor unit and will use some conceptsfrom the community.
First, if I merely run the board blank, this offers American state roughly 5-Volts on pin A7:
Code: [Select]
void setup()
and this offers American state zero.001V on pin A7:
Code: [Select]
void setup()
I have conjointly tested the higher than on pin D13 with a similar behavior.
I have a PNP semiconductor unit 2n2907 that I will manually drive with none problems at +5V on the collector if i take advantage of a 1kohm resistance on the bottom, connected to ground. the matter is that when I connect it to the arduino board on, i'm unable to drive the {transistor|junction semiconductor unit|electronic transistor|semiconductor device|semiconductor unit|semiconductor} with any measureable modification I cannot flip the transistor on or off - it merely floats its electrode, and shifts roughly zero.2V between being force high and low through the Arduino. this straightforward take a look at does not work to show the semiconductor unit on.
Code: [Select]
void setup()
Is there one thing that i am doing wrong here? Thanks in advance!
좋은 질문 입니까?
