주요 콘텐츠로 건너뛰기
일반적으로 통합 스크린을 포함하지 않은 이동하지 않는 컴퓨터입니다.
1488 질문 전체 보기
PC wakes up after sleep but monitors dont display.
Every night I put my computer to sleep, but when I wake it up the next day, it turns on, but the monitors don’t display anything, but its awake as once I had a youtube video playing and when i woke it up it started and it was playing. I just hit the reset button and after it boots up just fine, until it goes to sleep again and then the problem happens again. I havent tried anything yet, but I was wondering if anyone has a similar problem.
I recently changed my ssd and gpu. The gpu is an AMD RX 480, so im not sure if this is driver related or not.
Any help is much appreciated!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
답변 3개
선택된 해법
Updated GPU drivers. Problem stopped occuring. Thanks!
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
Sounds like the Power Options in Control Panel require attention?
Have you changed them?
Can you not get into Safe Mode & check the settings for display in Power Options?
If everything looks ok there, do a system restore to before the problem arose.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
I can get into windows just fine after a restart, so safe mode is necessary for checking the settings. Also, I don't think I have the system restore set up, and I don't know when it started, but it has been occurring for a while now. Probably 2 weeks.
의견 추가하세요
If you just upgraded to an SSD i would recommend quitting putting your computer in sleep mode every night rather than just turning it off and turning it on in the morning as it would save you some money on electric bills and also windows 10 with ssd is ultra fast booting up so there is no point in using the sleep mode..
해당 답변은 도움이 되었습니까?
점수 0
댓글:
Well, I sometimes like to keep things open overnight so I have them ready when I get home. Its just a convience thing.
의견 추가하세요
귀하의 답변을 추가하십시오
Cameron 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 55
