주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Replacement screen doesn't work with home button cable in board
Hi
I replaced my screen and battery after water damage (moving over my old Touch ID/home button to new screen) - phone appeared dead. I then removed the home button ribbon cable connector from the board (top right of the phone where the front camera ribbon cable etc connects) and noticed the screen fire up.
Phone appears to function fine (using home button accessibility on screen without ribbon cable connected)
Could the home button be damaged and causing a short circuit? Or does it sound like I have perhaps incorrectly reinstalled the button in the new screen?
Thanks in advance
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Hello
on iphone 6 the touch id flex is connected to mother board using a shielding plate. When you replace the screen did you change this plate or keep the original ? This should be replaced to avoid any doubt.
In mainy case i ve seen water destroyed the touch id function but i can t remind a case where the boot was not possible.
check your bottom connexion and check with a new shielding plate
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Nicola 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 51
