주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3531 질문 전체 보기
Touch Screen not Working After Replacement
Hi ,
I’ve recently went to replace my 5s’ cracked screen to a new on only to discover that the touch on the new screen was completely unresponsive. Thinking I had a dud screen, I sent it back and got a refund.
I tested my original screen with my phone again and the touch worked fine.
Ordering a new screen again, I went to install it today and again the touch is completely unresponsive! The new screen is an original apple screen so I doubt it is faulty the second time, however I doubt my phone is faulty due to it working fine with the cracked screen.
Honestly any help on this would be appreciated, because im stumped.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
The only thing I can think of is that you may have caused pry damage or long screw damage.
Did you put the screws back in the exact same location if not then that could cause long screw damage and prevent touch.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Make sure all your ribbon cables are properly seated. Ive had similar problems with iphones not working and the problem simply was a bad connection.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
kmes 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 55
