Trackpad click working only before Login - Finger movement never work!
Hello all,
after updating my macbook i have a serious issue with the trackpad - keyboard works perfectly.
- Trackpad clicking only works before the Login
- After Login the clicking doesn’t work at all
- Finger movements are never recognized (not before or after login)
I went to the apple store and they say that the trackpad is broken but they can’t explain why the clicking works before login in but not after.
I have done all of the resetting using all kind of key combinations but sadly nothing help. Also a reinstallation of the OS didn’t help.
Sadly I didn’t find someone with the same problem so Im thankful for any help!
Nora :)
좋은 질문 입니까?
점수
0
you say you done a reinstall ? was the trackpad working during the recovery process ?
lewis Barker 의
Thanks a ton for your answer! Only the clicking worked but it also didn’t recognize the movements of the fingers on it!
Nora V. 의
check for updates if possible if no updates found. perform clean OS install on your Mac if there was no hardware error you can easily fix the error
Amily Grey 의
