주요 콘텐츠로 건너뛰기
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
316 질문 전체 보기
Ds Lite Won't Read Games
I recently purchased a broken ds lite off of ebay to attempt repairing it as a little project. It won't read ds or gameboy games, so I assumed it just had some damaged pins. I opened up the ds and to my surprise, all the pins appeared to perfectly intact. I even put gentle pressure on each one and they all appeared well-attached to the motherboard. I then theorized that the pins could possibly be dirty, so after cleaning them off with some q-tips and rubbing alcohol, I assembled the ds and tested it. (Spoiler alert: that still didn't fix my problem, and all that my endeavors produced was a really clean ds lite lmao)
The two slots might need to be replaced, but it seemed like too much of a coincidence that both parts would be faulty.
I'm not sure what else could be the problem, if anyone has any ideas I'm all ears. Thank you!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 5개
A couple of questions, first of all, does the DS power on? Like power on but not reading games or does not power entirely
@luckytechguys The ds powers on perfectly fine, I just can't get any of my games to work. However, according to the listing on ebay, it does have issues holding its charge.
the top card slot wont read the ds card im putting in
Mine terns on but won't read games
Mine won't read the bottom one
댓글 달기
답변 2개
가장 유용한 답변
From what you are saying, it is most likely that the card reader is fried from heavy use by the previous owner(s). You generally cannot fix it separately. The best option would be to buy a new motherboard off ebay. They typically cost from 10-30 dollars used. When you are looking, look at the pictures of the listings with the left Styrophome cover is not damaged. This is the piece that will detect a card has been inserted. If you don’t think getting a new motherboard is worth it, look at your old one and see if any wires are frayed on the left hand side. Good Luck and tell me how it goes!!!
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
if you are keen you can desolder the card reader and put a new one in....
댓글 달기
Hey I thought this might help if it's not too late but I just purchased a ds lite from gamestop today and thought it a bad one not wanting to read games, in a non attempting way I had the games already inserted in the system while it was off and powered it on and boom the games finally were able to read (both ds and gameboy game) hope this
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
That's crazy, but I had this exact problem. Your answer was SOOO helpful. I spent 10 minutes cleaning my card reader, but still nothing. I was about to get entirely new parts, but I'm good now. Thanks!
Any advice for me? Ive tried what said multiple times but my DS lite doesnt want to work. It worked perfectly fine before, then just stopped working all of a sudden. Ive cleaning it a little but it doesnt seem to help. Any advice?
댓글 달기
귀하의 답변을 추가하세요
Buckets G. 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 32
30일 전: 124
전체 시간: 14,400
