주요 콘텐츠로 건너뛰기
2011년 7월 21일에 출시되었습니다. Core i5 또는 Core i7 프로세서. Thunderbolt. 이 기기는 Mac mini Server 구성을 실행하는데도 사용됩니다.
204 질문 전체 보기
Is the older macOS's a GPU killer?
I have a mid 2011 Mac Mini 2.5GHz i5 with AMD Radeon HD 6630M 256 MB
I was told that newer versions of macOS do not throttle down video resolutions or other demands on the graphics GPU automatically, and that this is causing excessive and undo wear resulting in failure of the GPU. Has anyone else heard this?
Is there a way to limit GPU demands manual, but within the OS not say site by site?
Finally, is it really worth replacing the logic board if the gpu can handle the demands or is there a board with upgrade to modern standards available?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Review the Mojave support page for what systems are compatible How to upgrade to macOS Mojave
댓글 달기
답변 1개
선택된 답변
I’m a bit confused on your questions:
The dedicated GPU in any mini is not throttled.
But! The CPU can be when the system overheats because the fan, heatsink or the sensors have failed. This is often a symptom the system has dust build up within the fan and logic board, I would recommend installing a good thermal monitoring app like TG Pro. Post a snapshot of the main window so we can see what you are encountering here 기존 질문에 이미지 추가하기.
You can alter the display settings choosing a lower resolution if you want to lower the GPU’s processing load. You can also alter Safari site by site as well altering the page to reader mode.
The 2012 model as well as the 2014 models use a different logic board design and the logic board is not the same. Even that won’t alter the limits of the systems cooling. In fact from what was seen in the new 2018 Mac Mini presentation it looks like Apple made a big effort finally addressing the systems limited cooling.
So the bottom line here is Your system likely needs a good cleaning and needs the thermal paste refreshed at a minimum. You may need to replace the heat sink and you likely need to look at lowering the systems heat buildup like swapping out the HDD for a SSD as well as look at upgrading the RAM (16 GB max).
Do remember MacBook laptops (all) and the mini are not gaming rigs! If you want that, you’ll need a system with much better cooling.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
JB Brighton 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 11
전체 시간: 695
