주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
one of the screw hold breaks and I can't turn on the phone
My iphone 6 has a long time problem with the display, some time it turns on when I pressed the power/home button but some time it doesn’t, while the sound and touch id all still works normally, so I suspected that it’s just a loosen cable problem.
So I opened the phone and unplug and replug the cables, but then I broke one of the screw holes when I try to put back everything, and now I can’t turn on my phone. Some searching shows that the screw hole that I broke was responsible for the power supply. How do I fix this?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
If you had a good microscope and excellent microsoldering skills you could rebuild traces that got damaged..it’s not a DIY job, either you’re a pro or you’ll have to find someone do it for you.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
I don't have the tools and skills. How much does it cost to fix this in stores?
@hoyun Cost of repair may vary with the place you are living..easiest thing is to find someone reputable in your area, but some repair shops offer mail in service too. Good news is many shops offer a no fix no fee service..your issue is quite straightforward repair, thus it won't be too difficult to get a quote.
댓글 달기
This is known as long screw damage. The traces underneath the logic board have been torn off by the screw, and now the phone is missing vital traces. This can be fixed by a microsolderer, but is a more of an expensive fix.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
hoyun 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 53
